Hi guys. It's the same plotter you have helped me with before, but a different problem.
A few days ago on switching on the plotter went into a burn in
routine, designed to stress the components directly after manufacture.
It moves backwards and forwards, knife up knife down etc. This routine
is stored in rom and accessed by pressing 'left arrow' as power is
turned on.
I took out the membrane switch, fiddled with the ribbon cables, hit it on the bench, and put it back. It worked for a few days.
Now I have the same problem.
I have taken the membrane switch apart so it is not being pressed. no difference.
I have disconnected the ribbon cable to the keypad PCB. No difference.
I have disconnected the ribbon cable from keypad pcb to the main logic board. The machine went into a different routine.
I figure it is the keypad PCB
My questions are; Can you confirm, comparing the parts list with the
photo, that component D1 (top/mid left) is the Diiode 1N4148. (It was
the brownest thing on the PCB, and when I picked at it with my finger
nail it broke).
Is there any likely culprit that is saying 'left arrow key is down'?
there are no components on the reverse side, and the left arrow key
signal comes in 5th across from j3 bottom left
There is comprehensive info on the machine here http://www.ioline.com/support/studio7/studio7_sm_r1.pdf pages 81 & 93.
I know, it's a long shot.
Cnc Jim
