Previous in Forum: Anyone Know the Material of AE 27   Next in Forum: Wanted to Know Soln
Problem from Nuclear System I - Thermal Hydraulics Fundamentals
12/04/2011 1:44 AM
Problem 7-4 Loss of heat sink in a sodium-cooled reactor (section II)A 1000 MW(t) sodium-cooled fast reactor has three identical coolant loops. The reactor vessel is tilled with sodium to a prescribed level, with the remainder of the vessel being occupied by an inert cover gas, as shown in Figure 7-26 . Under the steady operating condition, the ratio of the volume of cover gas to that of sodium in the primary system is 0. 1. At time t = 0, the primary system of this reactor suffers a complete loss of heat sink accident, and the reactor power instantly drops to 2% of full power. Using a lumped parameter approach, calculate the pressure of the primary system at time t = 60 seconds. At this time, check if the sodium is boiling.Useful dataInitial average primary system temperature = 980°FInitial primary system pressure = 50 psiTotal primary system coolant mass = 18,000 Ibmβ (volumetric coefficient of thermal expansion of sodium)= 1 .6( 10 ^- 4) ; oFcp for sodium = 0.3 BTU/Ibm OF (at 980°F)ρ for sodium = 51.4 lbm/ft) (at 980°F)Sodium saturated vapor pressure:p = exp [18.832 - (13113/ T) - 1.0948 ln T + 1.9777 (10^(-4)) T]where p is in atmospheres and T is in OK.
Answer: p = 87.9 psiT = 1190.7°F, so no boiling occurs
can anybody solve this question this is taken from chapter-7 of Nuclear system I- Thermal Hydraulics Fundamentals
Pathfinder Tags: Question
Re: Problem from Nuclear system I- Thermal Hydraulics Fundamentals
12/04/2011 2:21 AM
Do your own homework.
12/04/2011 2:11 PM
Have you tried re-creating the problem as a real world experiment?
Optionally re-read the text book (and associated text books) or ask your lecturer. All the information you need should be in there.
Jack - Nuclear Free down here.
Re: Problem from Nuclear System I - Thermal Hydraulics Fundamentals
12/06/2011 3:08 AM
"Shields up! Evasive manoeuvres, Mr. Sulu!"
Register to Reply 3 comments
jack of all trades (1); lyn (1); PWSlack (1)
