Previous in Forum: Delta Testing of Power Transformer   Next in Forum: SCR Cooling Water
12/04/2011 8:58 AM
I need to know that how much current injected in delta testing of power transformer.
Re: delta testing of power transformer
12/04/2011 9:07 AM
Why do you need to know? And why do you not already know?
Why do you not consult the governing specification documents that control such tests?
Re: Delta Testing of Power Transformer
12/04/2011 11:05 AM
The answer is 42.
Good Answers: 42
12/04/2011 3:30 PM
IEC 60250 gives everything required to be known about tan delta test. The basic knowledge should be an understanding of tan delta. If you know that everything is clear.A pure insulating material act as a capacitance. The current will be 90 degree ahead of voltage. Depending on the impurity there will be a resistive component resulting an angle and the tangent of the angle gives the degree of contamination in the insulating materiel which is measured and IEC stipulate a safe limit value of the insulation which is considered acceptance level
12/05/2011 3:33 AM
RTFM.
Register to Reply 4 comments
lyn (1); PWSlack (1); redfred (1); V.I.Abraham (1)
