Previous in Forum: 24 VDC Low Insulation Effect   Next in Forum: ETO Cranes With Active Front End (AFE) VFD
Difference Between Single and Three Phase
12/05/2011 12:13 AM
hi everyone,,
what is actually the basic difference between single and three phase loadflow...?
would be great if u share the links related to this...
thanks & regards,,
Pathfinder Tags: loadflow
Re: knowing the difference
12/05/2011 12:36 AM
They are basically the same...usually done with software program...these will give you an idea...
http://www.powerapps.org/PAES_LoadFlow.aspx
http://etap.com/load-flow-analysis/load-flow-analysis.htm
12/05/2011 11:14 PM
big thanks for you sir...
Re: Difference Between Single and Three Phase
12/06/2011 10:15 PM
Single phase is used for small loads and 3phase for large loads. In single phase the current consumed will be high but in 3phase it will be low for the same load thereby conductor skin effect will be low. For motors 3phase is more efficient than single phase
pnaban
Register to Reply 3 comments
doni_petrucci (1); pnaban (1); SolarEagle (1)
