Previous in Forum: Fluid velocity measuring system...plzzz   Next in Forum: difference.
10 comments
Air Casters
04/29/2007 12:36 AM
I am looking for a design to make air casters. I am moving a 1200 pound band saw I would like to do this with out a rubber skirt. I would appreciate any help.
Re: Air Casters
04/29/2007 7:09 AM
Look at air skates and jacks on google also see these guys: www.loadmovingsystems.co.uk
Re: Air Casters
04/29/2007 7:17 AM
Also note you will struggle to lift 1200lbs without a skirt using an air compressor alone. The skirt will also give you stability and control of the load, designs, the skirt is probably the easiest part of the design.
Re: Air Casters
04/29/2007 4:41 PM
I am thinking about using a 12 inch inter tube from a bicycle as a skirt. I did not know if I used three if it would be heavy enough to lift the saw. I was thinking that it would be better than on big inter tube. Any other ideas would be appreciated.
Re: Air Casters
04/29/2007 10:57 PM
buy some schedule eight pipe in 10 foot lengths and roll it to where you want it to go for gods sake. Borrow or rent a heavy lift pry bar with steel wheels and lift up the saw and place the pipe under it as it is moved to allow for an easy move -dont reinvent the wheel.
Re: Air Casters
04/30/2007 6:36 PM
I agree with #4... But if you have plenty of time and willing to accept a few trial & errors you might also consider using small rockets ... 4- one on each corner... (kiddin)
"Remember... if women don't find you handsome, at least let them find you handy." - Uncle Red
Re: Air Casters
04/29/2007 11:16 PM
smooth boards and grease, the grease goes between the boards
Re: Air Casters
04/30/2007 1:07 AM
Try Air Shuttle by AeroGo.
Re: Air Casters
04/30/2007 6:45 AM
Excellent method of moving heavy weights in restricted areas.
You need a fairly smooth floor
You need three air lifts for balance, equalisation, and size reduction of lift pad.
You should calculate your pad area fromA=1200/P divide by 3
P= psi
A = sq inch
You will be surprised how little air pressure you need
Inner tubes might not be tough enough, try wheel barrow tubes if you must three of these would have plenty of lift. Try not to make them any deeper than you have to.Leakage air and tube air is set to same pressure
You need a center balance point on top of each pad to allow leveling action to take place, make sure your top plate is strong enough.
make sure your air volume tank is big enough unless you have a large air compressor.
Good luck
Re: Air Casters
04/30/2007 8:08 AM
Garth,
Thank you for the help I will try the math and see what I come up with. I am looking for a mobile base that will be out of the way when not in use. From what little I have found about the air caster it sound like a good option. If I can make it work.
Re: Air Casters
05/31/2010 12:28 AM
try General machine tools, they carry a product call Hover Pad, 29 x29 inches, lifts 1200 pounds, around $250 google for best price. www.general.ca/pg_index/hoverpade.html
Anonymous Poster (8); garth (1); oomsarel (1)
You might be interested in: Casters, Air Compressors, Air Hose and Air Duct Hose
