Previous in Forum: Wanted to Know Soln   Next in Forum: Cleaning Molten Sulfur Rail Cars
Please Anyone Solve This
12/06/2011 5:35 AM
Problem 7-4 Loss of heat sink in a sodium-cooled reactor (section II)A 1000 MW(t) sodium-cooled fast reactor has three identical coolant loops. The reactor vessel is tilled with sodium to a prescribed level, with the remainder of the vessel being occupied by an inert cover gas, as shown in Figure 7-26 . Under the steady operating condition, the ratio of the volume of cover gas to that of sodium in the primary system is 0. 1. At time t = 0, the primary system of this reactor suffers a complete loss of heat sink accident, and the reactor power instantly drops to 2% of full power. Using a lumped parameter approach, calculate the pressure of the primary system at time t = 60 seconds. At this time, check if the sodium is boiling.Useful dataInitial average primary system temperature = 980°FInitial primary system pressure = 50 psiTotal primary system coolant mass = 18,000 Ibmβ (volumetric coefficient of thermal expansion of sodium)= 1 .6( 10 ^- 4) ; oFcp for sodium = 0.3 BTU/Ibm OF (at 980°F)ρ for sodium = 51.4 lbm/ft) (at 980°F)Sodium saturated vapor pressure:p = exp [18.832 - (13113/ T) - 1.0948 ln T + 1.9777 (10^(-4)) T]where p is in atmospheres and T is in OK.
Answer: p = 87.9 psiT = 1190.7°F, so no boiling occurs
can anybody solve this question this is taken from chapter-7 of Nuclear system I- Thermal Hydraulics Fundamentals
Re: Please Anyone Solve This
12/06/2011 12:55 PM
Look, this is an engineering discussion forum NOT a homework answer (or in this case homework working) cheat site.
You are not fooling anyone by generating a new CR4 login and asking the same identical question (which raises further questions as the previous threads have not been locked by CR4 admin. yet).
Read your text books and ask your lecturer (or others in your class) if you don't fully understand something, don't ask us - it is not what we are here for and homework questions are not allowed on CR4. If you are doing an online course try a nuclear engineering forum website (if there even is one).
12/07/2011 3:01 AM
Arrrrroooooooooogah! Homework alarm! Arrrrrroooooogah!
Good Answers: 61
12/07/2011 8:58 AM
Sorry, but I can't be bothered.
Good Answers: 101
03/02/2012 10:32 AM
CAN we answer your query? Yes.
Do we WANT to answer your query? A resounding NO!!!!
06/01/2014 10:47 PM
06/01/2014 10:48 PM
Register to Reply 6 comments
DVader1000 (1); energyconversion (1); jack of all trades (1); jubair073 (2); PWSlack (1)
