Previous in Forum: Suppression & Elevation   Next in Forum: instrumentation amplifier
Difference Between Analog Output vs Digital Output and Analog Input vs Digital
12/06/2011 11:35 AM
In Plc what is the difference between analog out vs digital output and sample device and
digital input vs analog input and its sample
Re: difference between analog output vs digital output and analog input vs digital i
12/06/2011 11:47 AM
have you tried Google?
12/06/2011 11:50 AM
The difference between analog and digital signals is so fundamental of a question that I really doubt you will understand the answer, but I'll try.
At any instance in time a typical digital signal can only be ON or OFF. The only exception is what's known as a tri-state digital signal that will be ON or OFF or X (not connected). An analog signal can be any value for an input and any value in a certain range for an output.
I recommend that you ponder my signature line and decide if you understand it.
