Previous in Forum: Pin Configuration of Ethernet Cable Connector RJ45   Next in Forum: Fuses
Dissolution Bath Heater Schematic
12/08/2011 8:04 AM
Hi,
Does anyone know where I can download a schematic (wiring) diagram for an ERWEKA DT6 Dissolution bath heater? Or can someone tell me the cause of my problem? When the heater is switched on it goes to alarm straight away, however, if I switch the on/off switch a few times it will stay on heating for a minute or so and then revert back to the alarm indicator. Can anyone help?
Re: Dissolution Bath Heater Schematic
12/08/2011 8:06 AM
Good Answers: 114
12/08/2011 10:46 PM
a wild guess would be the high limit probe has a bad connection or broken wire
dancing on the on off button confuses the controller for a minute
12/09/2011 12:43 AM
two causes as below,
1. protected sensor problem
2. Heater malfnction
a liitle suggestion, if you are not familiar with electric, just call to supplier for help
12/09/2011 6:15 AM
Thanks all for your replies.
Register to Reply 4 comments
Anonymous Poster (1); charles_cei (1); Garthh (1); Manfred2 (1)
