Previous in Forum: Auto Start Wiring for CAT 3508C (Remote Starting)   Next in Forum: Dissolution Bath Heater Schematic
8 comments
Pin Configuration of Ethernet Cable Connector RJ45
12/08/2011 8:00 AM
Dear all
We are working for a project where we will connect all the 10 Allen Bradley Compact Logic PLCs of a Corrugator machine through a LAN network. The pin configuration during installation of RJ45 connector is as mentioned in below picture. Please assist if it is ok? Any more instruction?
Good Answers: 21
Re: Pin Configuration of Ethernet Cable Connector RJ45
12/08/2011 9:51 AM
You need to contact your A/B representative or one of their integrator's. They can have a sales engineer assist you as there is more to net working these units then just cable and pin configurations.
12/08/2011 9:55 AM
Try this: http://www.bing.com/images/search?q=RJ-45_Pinout&id=2EF73B2163BBE962AA3304684E7188A09E37B131&FORM=IQFRBA
Whether to use TIA/EIA-568A or TIA/EIA-568B will depend on the situation. If all of the PLC's will be connected back to a switch that is "auto sensing, auto switching", then it doesn't matter.
12/08/2011 10:42 PM
the diagram you show tells you to wire it TIA/EIA-568A. But if your plant standard is 'B', no harm done so long as everything is the same. Nearly all of our PLCs are connected to the LAN and I can monitor and make changes on the fly from the shop.
Home is where the heart is!
12/08/2011 12:53 PM
12/09/2011 5:02 AM
Dears;
Can any one explain me about the difference/usage of following two types of Ethernet connector RJ45 configurations;
1) T-568A Straight-Through Ethernet Cable
2) T-568B Straight-Through Ethernet Cable
12/09/2011 9:00 AM
The two wiring standards, T568A and T568B vary only in the arrangement of the colored pairs....sources suggest using T568A cabling since T568B is the AT&T standard, but the US Government specifies T568A since it matches USOC cabling for pairs 1 & 2, which allows it to work for 1/2 line phones...". Your choice might be determined by the need to match existing wiring, jacks or personal preference, but you should maintain consistency. I've shown both below for straight through cabling....
RJ45 Pin #Wire Color
(T568A)
Wire Diagram
(T568A)
10Base-T Signal
100Base-TX Signal
1000Base-T Signal
1White/GreenTransmit+BI_DA+
2GreenTransmit-BI_DA-
3White/OrangeReceive+BI_DB+
4BlueUnusedBI_DC+
5White/BlueUnusedBI_DC-
6OrangeReceive-BI_DB-
7White/BrownUnusedBI_DD+
8BrownUnusedBI_DD-
Straight-Through Ethernet Cable Pin Out for T568A
(T568B)
Wire Diagram
(T568B)
10Base-T Signal
100Base-TX Signal
1000Base-T Signal
1White/OrangeTransmit+BI_DA+
2OrangeTransmit-BI_DA-
3White/GreenReceive+BI_DB+
4BlueUnusedBI_DC+
6GreenReceive-BI_DB-
8BrownUnusedBI_DD-
Straight-Through Ethernet Cable Pin Out for T568B
http://www.ertyu.org/steven_nikkel/ethernetcables.html
12/09/2011 5:11 AM
.....and some software to drive the signals correctly?
Good Answers: 18
12/09/2011 10:29 AM
Rockwell Software recommends using "managed" switches to reduce the risk of data collisions on your industrial network. Managed switches like the Stratix 6000 are pretty expensive, but they also contain tools to help with troubleshooting network traffic issues.
Here's a list of Ethernet switch recommendations from Allen Bradley's Ethernet/IP Performance Guide (Publication ENET-SO001A-EN-E-November 2007)
For Best Practice Use Switches with the Following Features:
�� VLAN
�� Full duplex capability on all ports
�� Autonegotiation and manually configurable speed/duplex
�� IGMP snooping
�� Port mirroring
�� STP
�� QoS
�� SNMP
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
Register to Reply 8 comments
Andy Germany (1); EElectrician (1); fixitorelse (1); Jsquared (1); Kilowatt0 (1); Signode (1); SolarEagle (2)
