Previous in Forum: Temperature Reduction in Shaded Areas Under the Sun   Next in Forum: Seismic Calculation of Tanks
"Load History"
12/08/2011 11:42 AM
What does "load history" mean? Is it something specific to FEA? Can someone give me a general meaning and use of this term please?
Thank you,
Re: "Load History"
12/08/2011 12:56 PM
It means the same thing as one of these. If you want a clearer answer you should provide more details. Any acronym (FEA) in your description should be defined to prevent confusion.
Re: "Load History"
12/08/2011 1:13 PM
I didn't mean to cause any confusion, but I thought this was a Mechanical Engineering blog. FEA stands for Finite Element Analysis, which I thought was a pretty general term in engineering. Do you know what "load history" is with respect to Finite Element Analysis?
Re: "Load History"
12/08/2011 1:33 PM
The sequence of application of loads (loading history) may be important. Especially, plastic deformations depend on a manner of loading. This is a reason for dividing loads into small increments in nonlinear FE analysis.
INTRODUCTION TO NONLINEAR FINITE ELEMENT ANALYSIS - http://www.mb.hs-wismar.de/
Register to Reply 3 comments
lyn (1); redfred (1); simektp (1)
