Previous in Forum: Design for Aligning Threaded Components   Next in Forum: "Load History"
16 comments
Temperature Reduction in Shaded Areas Under the Sun
12/08/2011 10:38 AM
The Steam for humidification of supply air is injected in the supply Air Duct by a standalone humidifier at the Roof that is open to the Sun.
The maximum ambient temperature for the electronic controls of this humidifier as specified by the manufacturer is 40C.
The ambient temperature at the location actually goes to above 52 degrees centigrade, therefore this humidifier must be housed in a shaded portion to bring down the temperature.
Would it be sufficient to simply enclose this humidifier in a non air conditioned but louvered steel enclosure as the means for reducing the temperature from 50 degrees to 40 degrees, or must some air conditioning be provided to bring the ambient temperature down? Would an insulation lining in the weather box (but without any air-conditioning or forced ventilation) be sufficient?
Re: Temperature Reduction in Shaded Areas Under the Sun
12/08/2011 11:48 AM
What is the temperature of the steam?
12/08/2011 3:00 PM
The temperature of the Supply Air Stream inside the Duct does not matter as the Humidifier is a stand alone unit about 3 meters away, sitting under the bare Sun. The effort is to somehow by providing a metal enclosure or an insulated enclosure bring down the ambient 52 degree temp down to 40 degrees. These temperatures are experienced for about 3 months in the summer. The Unit is in operation throughout the year to deliver the required Humidity in the otherwise dry atmosphere where the Relative Humidity is about 10 to 15 percent much throughout the year.
12/09/2011 3:08 AM
What is the temperature of the steam? The forum still doesn't know!
12/08/2011 12:06 PM
You don't say where you are located. If this control sits there year-round, then even with shading, insulation and good ventilation the control could still experience temps exceeding 40C. Perhaps the water being send to the humidifier can be used to keep the control cool by means of a heat exchanger and fan. And/or maybe a thermoelectric cooler. Or, if you don't need the humidifier in the summer, shut it down and store the controller in an A/C'd storage location for those few months.
Or you could inquire from the manufacturer what max temp the controller is actually rated at, and then decide what to do.
12/08/2011 3:05 PM
This is the question. What temperature would be seen by the controls if they are under the shade or say in an enclosure. As stated previously the ambient still air temperature is 52 degrees celcius. The entire effort is to somehow bring down the temperature inside the enclosure to 40 degrees. These temperatures are experienced for about 3 months in the summer. The Unit is in operation throughout the year to deliver the required Humidity in the otherwise dry atmosphere where the Relative Humidity is about 10 to 15 percent much throughout the year.
To reword the question, if the ambient temperature is 52 degrees, how much would it be in a shaded place on the roof?
01/11/2015 10:36 PM
Usually ambient temperature is 52 measured in the shade.
In the sun it will be much hotter.
01/12/2015 10:12 PM
Old thread and I score an off topic. Haha how funny given that OP has been given that information in various other posts.
01/13/2015 2:04 AM
your behavior at the time was professional
01/14/2015 1:53 AM
You should see me at work!
01/14/2015 8:27 AM
I wonder how you work. On the computer or in the field or both.
Anyway wishing you the best.
Thanks for the response.
More another time.
12/08/2011 12:28 PM
What do you think?
12/09/2011 12:23 AM
Outdoor ambient temperatures are normally taken in shade, so I think you still get 52°C--unless you are measuring the ambient temperature differently.
In a dry climate, a small evaporative cooler could be used to cool the electronic controls.
12/12/2011 12:49 AM
Tornado's response is the closest hit. Forgetting the humidifier business for a moment and going to basics instead, the question is reworded as follows:
When the ambient temperature is 52 Degrees C in unshaded atmosphere, what would be the approximate temperature at sea level, still air conditions under a shade? How can this be calculated or is this purely empirical?
12/12/2011 3:45 AM
The problem is in the conviction that a temperature-measuring device exposed to direct solar radiation yields "ambient temperature" It doesn't. "Ambient temperature" is the air temperature measured in the manner suggested by Tornado. In the shade.
There is no simple relationship between the ambient temperature and a, say, surface exposed to the sun. Is the exposed surface of black steel or white painted wood?
The OP needs to focus on the ambient temperature and that will give the operating conditions within a properly designed enclosure. If this is in excess of what is desirable, then means of supplementary cooling can be considered
12/13/2011 1:30 AM
Okay: The ambient temperature of 52 degrees was air temperature measured in the Shade as per consensus of Baffled and Tornado. So what would be the temperature if the thermometer at that location was exposed directly to the Sun? What I am trying to do here is to correlate the two readings. Suppose the thermometer is filled with mercury or other fluid and the sensing bulb is the color of mercury (in case of mercury filled thermometer). Conversely, should it be taken as a close enough approximation (from empirical readings) that the difference between the two is 5 degrees? and is that difference constant for all temperatures? For example when under the shade measurement is 52, without the shade it can be taken as 57 and when the ambient is 25 degrees, can the directly exposed to Sun temperature be supposed to be 30 degrees?
12/13/2011 2:15 PM
The correlation does not exist. I suspect that you are unfamiliar with a physical property of matter called "specific heat." You should Wiki that up.
What this says is that the temperature obtained by different objects exposed to the same quantity of solar radiation will differ.
If you expose a mercury thermometer on a thread to the sun's rays the thermometer will read its own temperature -i.e. the temperature of itself. A black-painted sheet of steel will be at another temperature. A white-painted sheet of plywood will be at yet another temperature. All these in the same ambient air temperature. None of them having the same temperature as the ambient air.
There is no general correlation.
Register to Reply 16 comments
Baffled (2); IdeaSmith (3); PWSlack (2); SolarEagle (1); solidspaces (6); Tornado (1); Usbport (1)
