Previous in Forum: RF MEMS Varactor   Next in Forum: Problem: PCI Card to Serial
Location: 6 floor, C building, Jia An Industrial Zone, 72# district of Ban An, ShenZhen, China.
UTEK UT-8000
12/09/2011 7:39 PM
hi everone,who can tell me details about the UTEK's product about UT-8000, it is difficuit to me to understand the user manual, and don't know the work mode
User-tagged by 1 user
Re: difficult
12/09/2011 7:48 PM
Are you talking about:
UT-8000
CablematicUT Drop Cable Trimmer • Color: Gold • Connector: PL-259 • Cable: RG-8/U & RG-213/U • Nominal Dielectric O.D: .285 • Nominal Jacket O.D: .405...
[MORE]
Re: difficult
12/09/2011 8:27 PM
Go with CISCO....SPAMMER JAMMER
Re: difficult
12/09/2011 7:57 PM
Type: UT-8000
About products:
The strongest multifunction interface converter in the world
The products are detailed:
UT-8000 is a strongest multifunction interface converter in the world, lightning protection is of supreme garad, one pair of intellectual fault detection warning functions of power input, specially for solve complicated the intersection of environment and lower the intersection of RS-485/422 and the intersection of system and the intersection of RS-485/422 and bus line designed to demand cut apart line concentrator (HUB) . This product supports the transmission rate to be up to 115.2KBPS, the built-in data buffer and the microprocessor, supply power and adopt and connect exchanging or the direct current power supply supplies power, safe and reliable, is very suitable for the application of project. In RS-485/422 work pattern, the perception data flow direction that the discrimination circuit adopted can be automatic, and autokinetic switch can enable the controlling circuit, solve RS-485/422 and receive and dispatch and change the time delay question easily. RS-485 / 422 interface transmission distance is big in 1200 meters, the characteristic is steady. Apply it to the industrial scenes, videos in the system of controlling etc. extensively, it is a section of of good performance multi-functional data interface that changes the products.
UT-8000 RS-485/422 HUB offers star type RS-485/422 bus connection. Users can improve RS-485/422 bus structure easily, cut apart the subnet section, improve the communication reliability. This characteristic has raised the reliability of the existing RS-485/422 network greatly, has shortened the preventive maintenance time of the network effectively. Reasonable can help you to design the unique high-reliability RS-485/422 system with UT-8000RS-485/422 HUB.
The characteristic of the products:
The strongest multifunction interface converter in the world,
Lightning protection is of supreme garad,
The power has redundant function,
Intellectual fault detection warning function,
High speed buffer storage
The properties of product:
1,Interface characteristic: RS-232C, RS-485, RS-422 standard of the interface compatible EIA/TIA
2,Electric interface: RS-232, RS-485, RS-422 interface is the connecting terminal
3,Transmission media: Wired and shielded wire of twisted-pairs
4,Operating mode: Asynchronous and half duplex
5,The signal is pointed out: 11 pieces of signal pilot lamp AC power (PWR) , DC power (PWR) , the instruction (SYS) systematically
Sending ( TXD1 ) , (TXD2) , receiving ( RXD1 ) (RXD2) , trouble (E1-E4)
6,Transmission rate: 1200BPS-115.2KBPS
7,Protect the grade:
DC power input end: Plus-minus each 5 times 8/20us, 5KA, separate by 60s each time
The input end of net mouth: The static tests: Contact 8KV, air discharge: Plus-minus each 10 times of 20KV, separate by 60s each time
USB input end: The static tests: Contact 8KV, air discharge: Plus-minus each 10 times of 20KV, separate by 60s each time
RS-232 input end: 10/700uS, plus-minus each 5 times of 1.5KV, separate by 60s each time
RS-458/422 input end: 10/700us, plus-minus each 5 times of 6KV, separate by 60s each time
RS-485/422 Ausgang: 8/20us, plus-minus each 5 times of 10KA, separate by 60s each time
RS-232 sets up the end: 10/700uS, plus-minus each 5 times of 1.5KV, separate 60s each time
8,Transmission distance: 0-1.2 kilometers (115200-1200BPS)
9,Working power: DC9-48V 2A
AC100-240V 12W
10,Size: 440mm 201mm 43mm
11,The environment for use: -40 to 85 ℃, the relative humidity is 5% to 95%
company contact page
Re: difficult
12/09/2011 10:58 PM
As Tornado said in this thread: http://cr4.globalspec.com/thread/74256
I admire your persistence - and despise your ethics.
Reporting you now.
Register to Reply 4 comments
Kilowatt0 (1); lyn (1); SolarEagle (2)
