Previous in Forum: UTEK UT-8000   Next in Forum: Is it Possible to Replace the Usage of Relay with Microcontrollers?
Location: 6 floor, C building, Jia An Industrial Zone, 72# district of Ban An, ShenZhen, China.
Problem: PCI Card to Serial
12/12/2011 4:45 AM
PCI card to serial, sometimes will anable computer death or blue screen, why? It's the technonical problem, I can't understand.
Good Answers: 88
Re: Problem
12/12/2011 6:46 AM
If you're tired of blue screens, you can always open the SYSTEM.INI file (running SYSEDIT from the Run command), locate the [386enh] part in the file, create the following entries if not there:
MessageBackColor=
MessageTextColor=
and give one of the values:
0=black, 1=blue, 2=green, 3=cyan, 4=red, 5=magenta, 6=yellow/brown, 7=white, 8=gray, 9=bright blue, A=bright green, B=bright cyan, C=bright red, D=bright magenta, E=bright yellow, F=bright white
  • Problem solved. (For instance, I do like Red Screens Of Death better). S.M.
Re: Problem
12/12/2011 7:32 AM
Read the instructions in the manual. You seem to have a problem understanding everything. Why is that? And why, after spamming us should we help you?
See #1 above!
Re: Problem
12/12/2011 8:01 AM
Register to Reply 3 comments
lyn (1); SimpleMind (1); SolarEagle (1)
