Previous in Forum: Petal Development of Toricone   Next in Forum: Condenser Vent Line Have One More Valve
9 comments
Boiler Mounting Question
12/10/2011 7:00 AM
Which valve used for supplying oil to the burner in the boiler...???
Re: Boiler mounting question
12/10/2011 8:10 AM
The oil valve.
Re: Boiler Mounting Question
12/10/2011 10:53 AM
12/10/2011 1:27 PM
Good Answers: 16
12/10/2011 2:02 PM
Hummmm Valve/Nozzle is hardly Tomatoes/Tomatoes is it?
12/10/2011 3:22 PM
au contraire, the definition is quite dodgy..."A valve is a device that regulates, directs or controls the flow of a fluid (gases, liquids, fluidized solids, or slurries) by opening, closing, or partially obstructing various passageways. Valves are technically pipe fittings, but are usually discussed as a separate category. In an open valve, fluid flows in a direction from higher pressure to lower pressure."
Good Answers: 16
12/11/2011 4:07 PM
Touche (technically)
Good Answers: 130
12/11/2011 9:48 PM
More like <sigh> eagle on a semantics tangent
"Which valve used for supplying oil to the burner in the boiler...???"
perhaps the OP means;
What kind of valve is best for supplying oil to the burner in the boiler...???
Good Answers: 16
12/10/2011 12:04 PM
The one located directly between the Oil Supply and the Burner, this would be the logical first step.... That is unless you provide more details, drawings or photos.
Good Answers: 61
12/10/2011 12:15 PM
Murali,
You will need very close flow control so I would suggest that you consider using a "Needle Valve".
http://www.vehydraulics.com/gb_series_needle_valve.htm
Do it once and do it right
Register to Reply 9 comments
34point5 (1); lyn (1); PennPiper (1); SolarEagle (3); Tim in Mexico (3)
