Previous in Forum: DEWOO PUMA 230B Parameters   Next in Forum: AC True RMS Measurement
9 comments
Neutral Shift
12/11/2011 12:29 AM
Does the neutral shift in single phase loads? If so what are the consequences?
Re: neutral shift
12/11/2011 12:54 AM
no...
Re: neutral shift
12/11/2011 1:45 AM
It can, if it becomes ungrounded.
For example, in a +120/neutral/-120 system, unequal loads on the + and - sides will will cause the + and - voltage to shift (still totaling 240).
Re: neutral shift
12/11/2011 4:26 AM
What you said is a 2 phase supply, the OP asked about single phase system.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Re: neutral shift
12/11/2011 5:03 AM
Dead wrong; what I described is single phase, opposite polarity. (There have been some 2-phase schemes separated by 90°, but they are pretty oddball.)
Re: neutral shift
12/11/2011 5:38 AM
+120V/ Neutral / -120V is exactly a 2 Phase system (180 deg apart) .
2 phase system separated by 90 deg is unheard of, where is it used?
Re: neutral shift
12/11/2011 6:13 AM
Baloney. +120/N/-120 is not defined as 2-phase; 180° apart is just the same phase, opposite polarity.
I already said that 90° separation is a bit of an oddball [historical, maybe]. Just because you haven't heard of it does not make it unheard of in general.
Re: neutral shift
12/11/2011 12:26 PM
Check out www.3phasepower.org/2phasesystems.htm. I'm certain I first read about it on CR4 several months ago. The question had to do with lighting circuits.
Good Answers: 181
Re: neutral shift
12/11/2011 7:56 AM
Scott transformers, I've never seen one but they exist
http://en.wikipedia.org/wiki/Scott-T_transformer
Next you'l be saying a 48 phase transformer cant exist. But they were used for murcury arc rectifiers.
Re: neutral shift
12/11/2011 10:48 AM
What Tornado and you are discussing is called a split phase system of only one phase. This is often erroneously called a 2 phase system because of the semantics of the English language but it is only one phase.
This is a very common mistake to make. I've made it here myself.
Register to Reply 9 comments
bravo88 (2); JWthetech (1); redfred (1); SolarEagle (1); TonyS (1); Tornado (3)
