Previous in Forum: 475 Communicator   Next in Forum: CQM1HCPU51
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Moisture Meter Reference Calibration Protocol
12/11/2011 3:42 AM
I saw one calibration certificate of Moisture Meter Reference Standard. In that certificate checking is done with three method. First according to AB.00.108 Protocol, Second according to AB.00.109 Protocol and third is done according to AB.00.110 Protocol.
Can anyone tell me these protocol is according to which standard?
If you can't find a way, make one........
Re: Moisture Meter Reference Calibration Protocol
12/11/2011 1:00 PM
Need more info...where did you see this?...was it in reference to a specific piece of equipment?...where are you located?..
12/11/2011 11:04 PM
Heat Seeking Moisture Meter Reference Calibration Protocol
12/11/2011 11:10 PM
see title for equipment type
Good Answers: 58
12/12/2011 7:05 AM
For your information, most moisture calibration in the USA has been performed using a chilled mirror hygrometer. NIST is currently switching over to ring down laser hygrometry. It depends somewhat on what type of measurements you want to make. The information I gave you is for atmospheric moisture. For moisture in wood, the methods are different. For moisture in fluids and other gases the methods are also different.
Good Answers: 70
12/18/2011 3:40 PM
GA from me welderman
Anonymous Poster (2); dj95401 (1); SolarEagle (1); welderman (1)
