Wise people, I have scoured the internet and a few libraries for a circuit diagram of a Bosch LE2 or LU2 Jetronic ECU circuit diagram without success.
In this unit the single PCB is surface mount on one side and leaded components on the other including two or three proprietry thick film hybrid modules.
This is an 'analog computer' using resistor values to 'program' the performance of the fuel injection system. The unit is intended to start open loop and switch to closed loop (via a heated Lambda sensor) as the engine warms up.
My objective is to repair a faulty unit I have which does not switch to closed loop operation. A spare unit I have works fine in the same vehicle. I have tried tracing the circuit, but that becomes very difficult very quickly.
Bosch are exceedingly unhelpful, simply saying that I should take it to a 'certified repairer' but I want to understand its operation and therefore have discounted that option.
I did find a very early Jetronic circuit or a BMW on the internet but it is several generations older than mine and therefore not particularly helpful
Could anyone help me to obtain a copy of this circuit?
