Previous in Forum: TSD – Short Time Delay Setting   Next in Forum: 12kV Fusible Switch - Backfeed
Substation Lightning Protection
12/14/2011 7:59 AM
Dear sir,
We have 161/34.5 kv Substation yard. We want to install lightning mast at a height of 15+3 mtr ( including shielding wire(alumoweld 7/2.59mm) ). Kindly confirm the angle of protection, whether 30deg or 45 deg, and how many lightning masts required.
Pls clarify the same and give us your valuable suggestion to improve our design
Re: substation lightning protection
12/14/2011 8:02 AM
Hire a local engineer to do the design work, or you'll be sorry.
Re: Substation Lightning Protection
12/16/2011 6:07 AM
30Deg is better option.As regards no of masts it depends upon the area coverage and hence you should be able to calculate.Good references have been given in the post which should help.
Good Answers: 170
12/29/2011 6:59 AM
Consult IS 2309.
electricalexpert65 (1); lyn (1); nesubra (1)
