Previous in Forum: Calculating Stress for High-Temperature Piping   Next in Forum: What's the Latest in Herringbone Grooved Journal Bearing Technology?
Designing a Power Transmission System
04/30/2007 7:45 AM
Hello all, i'm an adult learner from Belfast, Ireland studying for a HNC in manufacturing engineering, and I need your help. I have been asked to design a transmission system for a mechanical arm. This arm will carry locking nuts between two machines - a distance of 12 metres. The arm itself weighs approx. 66lbs. It can carry up to 121lbs at a time. 60lbs of this weight will be the nuts, leaving just over 60lbs for the total transmission weight - assuming the transmission is mounted onto the arm. these figures are entirely hypothetical and can be changed to suit if necessary. The problem I have is not locating the necessary belts/motors/sprockets etc., but calculating how to put them together to make this work, i.e. speeds/weights/distances etc. I hope I have provided enough information.
Re: Designing a Power Transmission System
05/01/2007 2:45 AM
You probably couldn't get all the information needed onto one page, including current design constraints, so...
Maybe start with speed. How many times do you have to move this 121lbs back and forth per sec/min/hr? Fit an appropriat acceleration and you will have an idea of the force involved.
Start at the start and stop when you've finished. Maybe not helpful...
Do or do not, there is not try, but there is failure...
You might be interested in: Nuts, Eye Nuts, Locknuts
