Previous in Forum: Half Round Thread Profile of Wire Rope Guide   Next in Forum: Clarification of Sour and Non Sour Pipe Lines in Refinery
8 comments
Motorized Screw Jack
12/18/2011 8:31 AM
Respected Sir,
I want to make motorized Screw Jack, in which the motor takes its power from the battery. But the problem which arises is of speed reduction which requires in model as motor speed is to high than required by the jack to operate and my next part of the question is that whether the torque of the motor will be sufficient for the jack handle to rotate. Sir please help me in this problem as soon as possible.
Thank You.
Re: Motorized Screw Jack
12/18/2011 8:37 AM
You mean like this...
12/18/2011 8:42 AM
yes like the one shown in the picture above
12/18/2011 8:52 AM
Just when I thought I'd seen everything.
12/18/2011 9:50 AM
I thought you wanted to make instead of buying such a screw jack. Well it is always good to see what commercial products already exist before you fabricate your own. You need to research about gear reduction drives. The question though becomes will it be worth your time to build your own screw jack.
Look at the fun this guy had trying to make a toaster.
12/18/2011 10:43 PM
i would use a 12 volt starter motor with a variable speed control or just a push button to release when the jack is up or down.
Good Answers: 120
12/18/2011 10:54 PM
I recall using electric trailer levelling jacks for steering satellite dishes in the 80's,
like these
levelling jacks etc
Per Ardua Ad Astra
12/19/2011 2:33 AM
Hi! go to: www.heartlandamerica.com pg 60 is 2000 pound electric jack ( 1-Ton )
works on 12V DC Makes old fashioned jacks obsolete! 1-ton 69.99 2-ton 89.99
hope this is helpfull!
Register to Reply 8 comments
Abhishek Rathi (1); aurizon (1); dadw5boys (1); Larry Burns (1); lyn (2); redfred (1); SolarEagle (1)
