Previous in Forum: Air Velocity Calculation in Pipes   Next in Forum: Root Face Clarification
Efficiency and Performance of an AC Unit
12/19/2011 7:54 AM
Dear All
As a requirement for choosing an effient airconditioning type/ model I usually review the COP and EER along with the electrical requirement of the unit. Obviously nowadays we are dealing with inverter types, however I would like to ask you what further parameters one should note in order to choose a good a/c unit. I also take note of the units noise emission.
Thanking you in advance
Ryan
Re: Efficiency and Performance of an AC unit
12/19/2011 8:55 AM
Ease of filter replacement...Warranty....Serviceability...Design problems...If you want to know how good an a/c unit is, ask a mechanic, the guy that works on them is the foremost authority...
Re: Efficiency and Performance of an AC Unit
12/19/2011 9:21 AM
I used to subscribe to "Comsumer Reports". (Not an endorsement)
They are unbiased, I think, and may be a good source of information.
Consumer Reports Website | ConsumerReports.org
12/19/2011 9:24 AM
12/19/2011 10:12 AM
I'm still subscribed to Consumer Reports online. Let me know if you want me to have a look.
Before making any major purchase, I also spend a significant amout of time looking at online reviews and prices from a variety of sources.
Many of the new units have a great SEER rating, but the quality is garbage.
12/19/2011 10:56 PM
In addition to the points mentioned here includign SEER consider to check the type of refrigerant used is it ecofriendly?. Check the materials used for various components.
12/20/2011 12:39 AM
A few other specifications/features that you may want to check into:
- tonnage of unit
- compressor type (number of stages, scroll type, reciprocating type etc.)
- condenser motor (single speed, two speed, variable)
- refrigerant type and if you'll need to change out the coil as a result
- type of control required
- if it has high/low pressure switches
- whether it has a compressor blanket
- type of thermostat that will be required (special two stage thermostat, etc.)
- does unit have diagnostics system
- furnace compatibility and SEER rating achieved from this
- cabinet construction
- warranty
After choosing a unit you will then want to weigh cost versus performance to see if the payback is acceptable.
Some people see the glass half full. Others see it half empty. I see a glass that's twice as big as it needs to be...George Carlin
Register to Reply 6 comments
kramarat (1); lyn (1); mrswamy (1); RyanC83 (1); SolarEagle (1); Zgolf (1)
