Previous in Forum: R-22 and R-407C   Next in Forum: Where do I Find Paddle Designs for Pin Homogenizers?
Seamless vs Welded Pipe
12/22/2011 9:39 AM
guys,
1. what is pro and cont by using any type of pipe above?
2. when is normally seamless or welded pipe been selected?
3. can a welded pipe replace a seamless pipe? what need to be checked?
4. how to weld a welded pipe with a thickness of 1.2mm?
5. what / where should i refer for this issue?
thanks
Re: Seamless vs Welded Pipe
12/22/2011 9:43 AM
Try one of these: List of welding codes - Wikipedia, the free encyclopedia
Without more information that's about it.
Good Answers: 61
12/22/2011 11:37 AM
SMLS (seamless) pipe is normally stronger then ERW (electric resistance welded), but money normally controls what is used.
Some Clients will not allow welded piping inside the battery limits of Process Units. The reason for this is that if a SMLS line is decommissioned they want to be able to reuse it for another service. They do allow ERW pipe to be used for piping in off site tank areas.
Both will work, and some ERW pipe approaches the strength of SMLS (DSAW - double submerged arc welded), but in "fragile" areas like offshore, its best to be safe then sorry so SMLS is used exclusively as directed by codes & company standards.
Do it once and do it right
12/23/2011 1:53 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Register to Reply 3 comments
lyn (1); PennPiper (1); skofitting (1)
