Previous in Forum: Reline or Replace Galvanized Drain & Cold Water Lines   Next in Forum: Seamless vs Welded Pipe
R-22 and R-407C
12/22/2011 12:42 AM
Can we use R-407C instead of R-22 without installing/changing anything in a cooilin unit?
Rgards
Umair
au.umair
Re: R-22 and R-407C
12/22/2011 1:06 AM
I'm not sure, but I think with R-407C the oil must be changed; but R-417C is a "drop-in" replacement. Check also if thermal expansion valves need to be modified, along with changes in pressure settings.
Egypt - Member - New Member Engineering Fields - Power Engineering - Pain and Joy
Re: R-22 and R-407C
12/22/2011 1:45 AM
Please, I am trying to understand the mechanical terminology, can you tell me what do R-22 and R-407C mean and what is their function?
Re: R-22 and R-407C
12/22/2011 1:51 AM
They are refrigerants...We don't ask the questions here, we give the answers....
Re: R-22 and R-407C
12/22/2011 3:22 AM
The correct location for the answer to this question is the technical helpline of the manufacturer that supplied the equipment. What was the answer to the question when the telephone call was made?
Register to Reply 4 comments
mona sayed (1); PWSlack (1); SolarEagle (1); Tornado (1)
