Previous in Forum: How to Avoid CO2 Accumulation on Ground Floor   Next in Forum: Integrated Project (Concrete or Steel Structures)
Hollow Circular Shafts Under Compression
12/23/2011 2:16 PM
hey guys;
i am doing an assignment on steel columns, my question is:
- i have to evaluate the section capacity of a hollow circular cross section, should i use the gross area or net area in my calculs ? also same issue with second moment of inertia...
your response is much appreciated !
Cheers and amerry xmass+ happy new year...etc
Re: Hollow Circular Shafts Under Compression
12/23/2011 6:36 PM
Net.
Good Answers: 179
12/24/2011 10:15 AM
Tornado is quite correct. Use the Net Area (in.^2), Moment of Inertia (in.^4), and Radius of Gyration (in.) in the calculations. These values are tabulated in the Steel Manual or steel manufacturer's literature.
Q: You do know how to use the AISC Steel Manual, don't you?
Note: Not to confuse things (and other issues), but you only use the Gross Area (etc.) if the interior void of a round, square or rectangular steel column is filled with a suitable concrete mix, then the entire section becomes a "Transformed Composite Section".
12/25/2011 4:38 AM
Can't help you. I can never seem to get beyond the first moment of inertia.
12/25/2011 8:58 AM
thank you all :), it felt like a stupid Q but i was abit confused !, well i know how to use the eurocode which is most relevant to me :P, thanks again :)
Register to Reply 4 comments
CaptMoosie (1); jo (1); lyn (1); Tornado (1)
