Previous in Forum: Selection of Step-up Transformer   Next in Forum: Harmonics Impacts and Remedy
8 comments
Need a Precision Pulse Stretcher
12/24/2011 12:17 AM
I need a circuit that will accept a pulse of width x (x being 1-10ms) and output a pulse of width nx, where n is a fixed whole number in the range 2-24. Ideas?
Pathfinder Tags: pulse stretcher
Good Answers: 120
Re: Need a Precision Pulse Stretcher
12/24/2011 10:36 PM
Per Ardua Ad Astra
Good Answers: 102
12/24/2011 11:00 PM
12/25/2011 12:09 AM
Thanks so much, Wal. It's an ingenious circuit and will do the job for me. GA!
12/27/2011 9:50 AM
Use the technique suggested in Wal's post but use an EPLD. You will be able to get much better resolution because you can build counters of almost any length. If it's a one off project you can use an eval. kit.
In my opinion Altera's Quartus (free download) is easier to use than Xilinx design suite if you're used to designing stuff with more traditional logic chips.
12/27/2011 11:19 AM
More good info, thanks! I'll look into that stuff.
Good Answers: 102
12/27/2011 9:14 PM
Would this be for your "spark timing advance meter"?
12/27/2011 9:54 PM
Yep. I got concerned about the size of the pulse when I found the meter movement, which I assumed to have a very low resistance, turned out to be 50 ohms. This meant I needed a 60 volt supply and a pulse of 1.2 amps. Even tho the pulse is narrow, I wondered what 1.2 amps would do to the movement, and I really wasn't keen about the 60 volt supply either. So my thought was to stretch the pulse so it wouldn't have to be so powerful. But now I have another idea: instead of just using one cylinder, I'll use all 8 of them. By taking the firing signal from the coil and putting 4 marks on the torque converter (since 4 holes fire each revolution), I should be able to reduce the voltage to about 8 volts and the current pulses to about 150ma. I'm rewriting my circuit paper and will post it soon. And I've finished reworking the meter and will post a pic.
12/27/2011 11:42 PM
Register to Reply 8 comments
aurizon (1); Randall (1); SSCpal (4); Wal (2)
