We have 6 MW diesel engine. Nowadays our DG set is standby and runs only 2-3 hrs daily to control MD.
For jacket cooling of engine 30KW electric heater is being used and minimum water temperature required is 50 Deg C. Jacket cooling is done on slow rate to avoid thermal stressing .
Water flow rate is approx 8 m3/hr.
when engine runs heating is stopped automatically and if engine stops then heating started to maintain the jacket temperature.
please suggest any other source to heat water on slow rate for above application to cut electricity auxiliary consumption.
