Previous in Forum: Mark V   Next in Forum: Reverse Power Checking
What Are The Possible Interlocks For a Freon Compressor??
12/27/2011 10:23 AM
I jst know conditions about suction pressure,delivery pressure,oil pressure,dp between suction and oil pressure etc..would really like to know more about various conditions for stopping/starting the compressor..
Re: What Are The Possible Interlocks For a Freon Compressor??
12/27/2011 11:00 AM
Are you having a specific problem or just seeking a tutorial on controls in a compressor circuit?
12/28/2011 1:57 AM
No..just want some information for doing a project..plzzz help.....
12/29/2011 11:49 AM
Some common interlocks for a freon unit:
1 Slider valve closed (used on screw comp)
2 Low suction pressure (not a problem on start up)
3 Hi discharge pressure
4 Low oil pressure (usually a difference between oil and dish. pressure)
5 Too low or high Oil temp (needs to be above minimum for start up)
6 Oil level in separator (if equiped) or sump
7 Cooling water flow( depending on application)
8 Some units may have high level trips on chiller or flash drum or reciever
This is a few but they are all a little different depending on age and whether it is hardwired controls or PLC.
12/29/2011 11:57 AM
Oil pressure is the difference between LOW pressure and oil pressure.
12/30/2011 8:15 AM
Thanks Fredski and Altennant....Its for programming in PLC..I'm just a beginner..Thank u so much for ur help...:)
altennant (1); Fredski (2); instman (2)
