Previous in Forum: EN8, EN9 and Many Other Materials   Next in Forum: Tube Material Impact On Selection Of Baffle Material
Presence Of Moisture In Turbine Lub Oil.
12/29/2011 10:58 AM
What are the effects of presence of moisture in Turbine Lube oil System? How Moisture effect turbine bearings & what is the tolerable limit of the moisture?
Re: Presence Of Moisture In Turbine Lub Oil.
12/29/2011 11:15 AM
Looking for home work reply !!!!!!
12/29/2011 11:55 AM
Any moisture is bad. Moisture can cause rust on bearing surfaces. Moisture also reduces the viscosity and lubricity of the lubricant. Oh, foam isn't good either.
The lubrication oil data sheet should give you information. The bearing supplier may have an opinion, too.
Keep it dry!
01/02/2012 9:32 PM
adds on: Moisture can cause caviataion action within the bearing damaging the white metal.
