Hi guys,
I am planning to make a digital thermometer circuit with LED display. I have this circuit which uses BC108, but the accuracy the site said was just ±1ºC, and I want it to be more accurate.
http://electroschematics.com/6065/diy-digital-thermometer-circuit/
I understand the VR1 is for zero setting, ie. at 0ºC I would have to adjust it to display '0' (which happens to also be the voltage the output ought to have). Is there any way to make this more accurate? I thought BC108 was used in Pre-amplifiers, I was thinking of using LM35 originally. Would that be better?
I was thinking of the display part later (I might even get a ready-made Voltage-to-7 Segment-LED-Display), but for now I need an output that linearly changes with temperature (for atleast a good range of say 150ºC or 200ºC).
