Previous in Forum: Digital Thermometer Design   Next in Forum: Power Lines Phasing Ddentification
Wohlenberg Guillotine Enigma
12/29/2011 1:43 PM
HELLO GUYS!
Have any of you guys have any experience with wohlenberg cutters?
I have been struggling with a wohlenberg MCS-2 TV guillotine cutter for over a week now. As far as I can tell, all led relay lights report no irregular conditions. However my K-50 and K-51 contactors for the knife magnetic-clutch will not turn on.
I am having trouble finding a point to test which will send me in the right direction,the german schematic that I have is has thrown me for a loop I am having trouble tracing the control paths. The redundencies through the grips,barriers and relays have tripped me up numerous times. I could really use some input.
Sincerely Reduced To Rubble, Marty
Re: Wohlenberg Guillotine Enigma
12/30/2011 8:01 AM
These guys may charge you a some money to help, but it might worth a try to contact them.
http://www.nyco-systems.com/Products/mfr.php?mfg=6347
http://www.colterpeterson.com/
12/31/2011 6:18 AM
l had overcome related problems twice; (1)Try check all the N/C / N/O contacts on all the contactors using ohmsmeter for continuity with mains switch off ( 2) check the wires from the gripswitches for continuity to the safe C module using ohm meter with mainswitch off. GOOD LUCK.
Good Answers: 102
12/31/2011 7:22 AM
You have a schematic???!!! In German no less....
Lucky sod!!!!!
You want to try tracing out wiring without any information on a 20 year old retired Japanese guillotine completely labeled in Katakana script, rebuilt in Vietnam...
Now that's an exercise in returning to first principals.
I hear your pain. Good luck mate!
Register to Reply 3 comments
adeyemi. (1); kramarat (1); Wal (1)
