Previous in Forum: Difference in Hydrotest pressure as per ASME Sec.VIII Div.1 UG-99(b) & UG-99(c)   Next in Forum: Cold Box Layer Picture
9 comments
Calculation Procedure for Inlet HP Steam Nozzle Size
01/01/2012 5:29 AM
Following are my Quires:
For our Plant , Reqd. Steam Turbine 8.64 MW,
Having inlet HP Steam Temp.=400 Deg. C; Pr. = 42 Kg/cm2. ; supplied steam: 110 Tonne/hr. HP Steam.
Turbine Type: Back Pr.cum Extraction type.
Extraction: MP Steam Max. 40 Tonne/Hr with PR. 13 Kg/cm2; Temp. 300 Deg. C & LP Steam Extraction = Max. 40 tonne/Hr. with Pr. 3Kg/cm2, Temp. 200Deg. C
As the Extraction depends on our process requirement.
Now I want to know the procedure of Calculating the Steam Inlet Nozzle Size or what should be the HP steam pipe line size at the inlet of Turbine, from the standpoints of above data.
Please inform me If any more info. required in this regard.
Re: Calculation Procedure for Inlet HP Steam Nozzle Size
01/01/2012 11:02 AM
What is your desired steam velocity and could you give pr in psig ?
01/01/2012 1:16 PM
inlet HP steam Velocity= 70 mt./sec= 229.6 ft/sec; Pr. = 42 kg/cm2= 596.4 psig; Extraction , MP steam pr.= 13 kg/cm2= 184.6 psig & LP steam Pr.= 3.2 kg/cm2= 45.44 psig.
Regards
01/01/2012 1:40 PM
According to my calculation...
pipe size = ~ 4 inches
Actual velocity = 184.8 ft/sec
Pressure drop per 100' of pipe = 18.6 psi
01/01/2012 1:58 PM
Thanks a lot for calculation, can you please let me know , how do you calculated with sized approx 4 inches ?
Regards
S Jana
01/01/2012 2:18 PM
If I tell you , how will you ever learn ? I use shortcuts, you must learn the long way...the proper way...
01/01/2012 9:32 PM
Sir, here how you get the actual velocity 184.8 ft/s? actually, before this discussion,i gone thru some engg. text books , but surprised no one mentioned , so to dig up the the formulas/calculation whatever generally those are used to calculate such types of Size calculation, please give me the hints or refer me the some books/ internet resources where i can get the same & learn .
Regards
01/02/2012 7:10 AM
It would be inappropriate to learn on this size of turbine. What does the employer expect (rhetorical question)? This stuff should be job-related training, not the subject of responses to an anonymous international engineering forum!
01/02/2012 11:47 AM
01/02/2012 12:56 PM
Dear Sir, thanks a lot for your steam engg. tutorials, if you've more don't forget to post it. yes i did my homework, get a solution that exactly fits your saying" must learn thru a long way- the proper way". yes I've taken Sp. Volume of the HP steam from the steam table and gotten the result. Thanks for supporting.
Regards
Register to Reply 9 comments
jana_subrata (4); PWSlack (1); SolarEagle (4)
