As I understand it, LPG in compression in the storage tank of a motor vehicle at normal temperatures, say 25 C, has a tank pressure of about 50 psi.
The fuel rail (manifold) in a modern day EFI engine (I believe) also operates at about the same pressure - the fuel manifold in some Caterpillar engines operates at 75 psi.
Modern EFI engines have Engine Management computers to control fuel injection pulse length to match load requirements.
What are the objections, difficulties, impossibilities associated with direct liquid injection, controlled by Engine Management computer, of Liquid Petroleum Gas into the engine intake manifold, or into the cylinder as in Diesel engines, rather than the present LPG systems where the LPG is first passed through a "cooker" to de-liquify it and then fed by some form of gas injector (venturi) into the inlet manifold airstream?
I am sure better brains than mine have contemplated this idea, but I have heard nothing on it.
The de-liquifying of the LPG was, of course, the only way LPG could be inducted into carburetter engines in the old days, but maybe the "ccokers" and the rest are still used because of habit and to ensure the continued use of these relatively expensive pieces of gear.
Ok, so what cooks?
