Previous in Forum: Conversation of Air Whorl Energy Produced by Fast Moving Vehicles   Next in Forum: Fuse for 2000 Cavilear Cigarett Lighter?
15 comments
Automotive Service Centre Standard
01/06/2012 6:56 AM
Does any one has an automotive service centre standard, or something similar
Good Answers: 16
Re: Automotive Service Centre Standard
01/06/2012 9:36 AM
Never heard of a standard per say, although it seems that they all strive to make as much $ as possible for the least amount of actual work. And I think they all use the N/A motto (KEEP COMMING BACK).
I would seriously think your question should include a specific geographic location, who knows in some countries there may actually be a code or standard.
01/06/2012 2:28 PM
Whatever you do, don't give us any information than you absolutely have to.
Motor Age - Automotive training, certification & parts info ...
Good Answers: 58
01/06/2012 3:24 PM
Your question is rather vague but I will do my best.
I don't have a written source to reference so I will go from memory:
One Milton "Ding-Ding" Bell and 200' of actuator hose.
At minimum - Two "Full Service" gas pump islands with lockable oil can racks at each.
At minimum - Two full time gas jockeys that run out of the station when the bell "Ding-Dings" to fill the customer's tank, wash the customers windshield, check the customer's oil, and in some cases (female customer) check the customer's tire pressure.
Gas jockey's to wear clean and pressed white dress pants and shirts with matching "Soda Jerk" caps.
Gasoline prices to be 21¢ for regular and 28¢ for "Ethyl"
At minimum, two bay garage (typically) with a car on each of the two lifts at all times.
All glass panel bay doors.
Very greasy and incredibly slick garage floor.
Air compressor with no in-take baffle so as to increase noise while running and no safety guard to cover the 75 pound flywheel spinning at 750 RPM's
One very grimmy tire dismount/mounting machine.
Ample supply of discarded lead weights and valve stems scattered about the garage floor.
At minimum 30 discarded tires piled high against the outside wall of the garage.
"Fan Belts" of every size hanging from a rack along the ceiling.
At minimum, two mechanics.
All Mechanic(s) to wear a dark work uniform or overalls and required to chain smoke Viceroy or Camel non-filter cigarettes.
Main (office) area of station with two, in some cases three walls - all glass.
Main office walk-in door with simple bell tied to inside, upper lock side corner.
Alternate Adder - 2" blinds on all office windows and door.
Candy/Gum vending machine with a big mirror on it.
1¢ Gum Ball machine.
A wall rack with many road maps.
At minimum, two or three new tires on display in the office area.
At least one credit card carbon slider machine.
All employees required to have at least one greasy rag hanging from back pocket.
Two water fountains, one in the office area that should be kept semi-clean and one in the garage that must be maintained filthy at all times.
And last but probably the most defining attribute of any automobile service center - RESTROOMS MUST BE MAINTAINED AT ALL TIMES SO AS TO MAKE A GOAT PUKE.
That is all I have for now. If any more comes back to me I will post here.
In the meantime if any of the other "oldster" members recall any of the "standards" feel free to add to the list.
Disclaimer - From memory of working two summers at "Uncle Lou's" - Lou's Sinclair Service Center in the mid 60's
Good Answers: 16
01/06/2012 3:41 PM
You hit the nail SQUARLEY on the head! You took me back to one of my first tax paying jobs when I was about 16 years old....
It was an Exxon Station on Northern Avenue very close to Sparrows Point Steel Mill in Baltimore, Md. Both long gone, but the memories remain.
Tim
Good Answers: 58
01/06/2012 3:44 PM
There you go - Glad to have helped
Good Answers: 16
01/06/2012 3:49 PM
Oh and I almost forgot.... very GA
Good Answers: 58
01/06/2012 3:52 PM
Aw shucks but Thanks!
01/06/2012 4:06 PM
Well done. But you forgot the fingernail checks.
All mechanics are required to have grimy fingernails and knuckles.
Good Answers: 58
01/06/2012 4:24 PM
Ah shoot - so simple, I should have remembered that and the occasional mid morning beer breath - not that that's a bad thing
01/06/2012 4:30 PM
"occasional mid morning beer breath "
Or, perpetual mid morning beer breath?
Good Answers: 70
01/06/2012 6:33 PM
we used to knock a few cents off if, we pumped "Ethyl" behind the station
Reply Score 1 for Off Topic
Good Answers: 58
01/10/2012 8:18 AM
We used to get a lot of mileage out of that one:
David, where is your brother?
Oh, he is down at Uncles Lou's pumping Ethyl.
Good Answers: 123
01/09/2012 10:53 AM
Sal? Sal? Is that you? When did you move out of NY?
What about the tow truck? And the wiper blade stand? And how many of you remember the lovely attendant that checked your oil for you? How many times do you think he stuck that spout into an empty oil can and charged you for it anyway. (needs beer money)
Bob
Good Answers: 58
01/09/2012 10:57 AM
Hi Bob,
Yes, I also forgot the tow truck, usually pretty ragy and always with a ripped up front seat as I recall.
"needs beer money" too funny!
Good Answers: 123
01/09/2012 11:43 AM
The tow trucks were rough by any standard. The power for the heater fan was tapped right into the ignition coil power.
Bob
Reply to Forum Thread 15 comments
bob c (2); dj95401 (1); KJK/USA (6); lyn (3); Tim in Mexico (3)
