From all of the answers received relative to my previous question regarding limiting inrush current. I have decided to go with the resistive load and switch it out of the circuit using a parallel switch. Question: If my sourse is 240 vac and I want to limit the current to 4.8 amps, then I would use a 50 Ohm resistor as determined by R = V/I, but what power handling capacity would the resistor need to be? The largest ones that I can find are 100 Ohms, which seems to be well short of what should be required.
