Previous in Forum: Weight Calculation   Next in Forum: New Peroxide and Ozone Vapor Disinfectant
Liters Per Minute Thru 15mm Sprinkler Head
01/09/2012 7:03 PM
Is there a formula to determine the theoretical liters per minute flow thru a 15mm ipt fire sprinkler head at 206 kpa?
Thanks for any help
Re: Liters Per Minute Thru 15mm Sprinkler Head
01/09/2012 7:26 PM
yes
01/09/2012 7:55 PM
um, thanks for that. Any chance you could tell me what it is?
Good Answers: 53
01/09/2012 8:47 PM
The theoretical flow should be zero until there is a fire.
If you know the K factor of the speific sprinkler you can figure it out, Wiki has a nice explanation. Not all 15mm ipt heads have the same design or K factor, therefore they may flow differently. The fluid also effects the flow, foam will not flow the same as water.
01/11/2012 2:36 AM
This link has the formula I was looking for. Thanks
01/09/2012 9:36 PM
There is much more than a formula to be learned.
Fire Sprinklers.
01/10/2012 3:19 AM
Formula? Er, why not use the manufacturer's performance curve supplied in the sales information?
Register to Reply 7 comments
Ace Boeringa (1); Fredski (2); lyn (1); new zealand ken (2); PWSlack (1)
