Just I want to know the testing procedure of the MV circuit breaker timing test:
1. If this test could be done, while the breaker is connected to the test through the test cord. or the test cord has to be disconnected and the DC voltage supply goes through the test instrument and connected to open/close coil.
2. Why the HV single breake per pole breakers have two trip coils and one close coil. and when you test the trip coil do you test one at a time or you have to test both at the same time?
Thank you all,
