Previous in Forum: Petrochemical Output From Biomass Boosted by 40%   Next in Forum: OEM Agency Agreements
15 comments
How to Create Fog on Glasses
01/11/2012 3:39 AM
Hi sir,
I am interested in creating fog behind lenses and at the same time how effectively fan is clearing the fog. I am doing one experiment for my project work. how to create natural fog behind lenses. Is there any standard setups will be available. Please guide me
Re: How to create fog on glasses
01/11/2012 6:49 AM
Drop temperature below dew point to create fog, raise temperature above dew point to evaporate...
Good Answers: 266
Re: How to Create Fog on Glasses
01/11/2012 7:33 AM
Question if you create it whats natural about it?
01/11/2012 11:15 PM
oh shut up ...
biggiginthesky
Register to Reply Off Topic (Score 9)
6
01/11/2012 7:52 AM
To fog both sides of the lenses in a pair of eyeglasses is easy. Stick the glasses in a cold zone like the freezer side of a refrigerator. After they've chilled for a while, bring them out into a room with even a moderate amount of humidity (30% rel humidity or higher) and both sides of the lenses will fog almost instantly.
If you want to fog just one side of each lens do the same but put an insulating layer against the other side.
If you want to fog just one side of each lens, but you still want to be able to shine light through the lenses, you could try placing a long open tube against the other side -- like the dew shield astronomers use to keep the front lens of a refractor or Schmidt-Cassegrain telescope from fogging over.
Good Answers: 69
01/11/2012 9:02 AM
Serendipity ! Thanks to you for that note on open tubes, it would allow me to use my telescope in cold-humid conditions, I'll do a little more research on the matter.
Good Answers: 58
01/12/2012 8:45 AM
Just to add another factor to your project, consider that when water condenses on windows, it forms small droplets (fogging). This is because the window is hydrophobic. Thin transparent coatings (such as Rain-X) can be applied to the window to make the surface hydrophilic. When this happens, condensed water will form a film and will not impair vision.
01/12/2012 11:14 PM
My understanding is that Rain-X creates a strongly hydrophobic (repels water) surface layer which causes the water to pull together into droplets that run off, leaving a clear dry water-free surface. This is optically non distorting. Normal glass has silicates which bond to water molecules (hydrophilic), causing waviness in seeing through it because of the varying thickness of the water layer.
Good Answers: 58
01/13/2012 9:25 AM
I think you have it backwards. A surface that fogs at the dew point temperature is hydrophobic to water and is not wet by the droplets condensing on it. A series of these droplets is called fog and is an array of micro-lenses. If the same conditions exist on a hydrophilic surface, the contact angle between the water and the condensing surface is smaller. The water wets the surface and forms a continuous sheet that is transparent.
01/14/2012 7:16 AM
Have you tried using Rain-X? I use it on my car windshield. I live in a "frost pocket" where radiational cooling creates a locally lower temperature in the air, with the result that frosting or fogging (depending on the glass temperature) of the windshield is very likely in the morning. The apparent disagreement between us seems to be in the details of whether it is easier to see clearly through a hydrophilic or a hydrophobic surface. A fog can be created on a hydrophilic surface by preferential condensation onto the micro-surface of the protodroplet, making the droplet grow. The area of the windshield which is not wiped by the windshield-wipers has a later of deposits which cover the Rain-X and create a hydrophilic surface, whereas the area inside the wiped area has exposed Rain-X, and is hydophobic. This provides an opportunity (before the wipers are used) to examine the differences nearly every morning - and I do. Do you?
Good Answers: 58
01/14/2012 9:55 AM
My bad, you are right. However, from "The basics of Physics" by Rusty L Myers, "Conversely, in other cases substances may be used such that the adhesive forces are greater than the cohesive forces causing the water to spread. Wetting agents used in dishwashers are prime examples." I use a wetting agent in my dive mask to prevent fogging.
01/12/2012 8:48 AM
just use a small table top humidifier and a lab stand to hold the glasses above it
01/12/2012 11:26 PM
Please clarify (!) your post. Are you desiring to create a fog behind lenses, or a fog on the surface of lenses? A post with more details in the question will receive more detail in the answers.
01/13/2012 2:56 AM
When I get out of car many a times the lenses get foggy.I need to take some tissues and clean it ,before I start walking.Sometime it takes almost 2 minutes. Is there any way that I can avoid this job and the delay of time taken to clean the glasses? Are there any special type of glass which do not get fogged or get fogged much less ,so that I can start walking immediately after getting off the car?
Good Answers: 102
01/13/2012 3:54 AM
Have you tried wiping your lenses with saliva yet? This helps prevent fogging.
If you take your glasses off and let them warm up a bit after alighting from your airconditioned vehicle you can save having to wipe them. Walk while you are waiting for them to warm up.
If your vision is too impaired to walk without ocular aids then have another pair of glasses that are stored warm.
Good Answers: 58
01/13/2012 9:33 AM
You can create fog by operating the lens below the dew point temperature of the ambient atmosphere. You can quickly clear the lens by heating it. A thin layer of tin oxide on the glass is transparent. If you run electric current through the conductive layer it will quickly clear the fog. This is how many window defrosters work.
Register to Reply 15 comments
biggiginthesky (1); Guest1947 (1); ozzb (1); reefdiver (1); SolarEagle (1); Usbport (1); Wal (1); welderman (4); woodpower (3); Yahlasit (1)
