Previous in Forum: Minimum Length Supporting Legs Sleeves for Floating Roof   Next in Forum: Pneumatic Leakage Crises
Hydrotest Temperature As Per UG-99(h)
01/13/2012 12:10 PM
Dear all,
This refers to UG-99(h),
Where in code recommends to have difference of 17 degree C in hydrotest liquid temperature & MDMT.
Here I would like to know that it is referred as rated MDMT (Calculated using UCS-66 rules) or
Equipment MDMT (which is mentioned on Process datasheet).
Que. 1
I have case wherein my Equipment MDMT is 16 deg.C
I have water in winter condition in the range of 20 to 25 deg C.
Though UG-99(h) is recommendation not mandatory but it client specification requirement.
Shall I have to increase temperature of water to 16 + 17 = 33 Deg C.
Can I consider Rated MDMT here which is in my case is -10 deg c so as per UG-99(h) hydro test liquid temperature = -10 +17= +7 deg C. so I can use water at temp.20 Deg C.
I have referred Non-mandatory appendix L - Example 9 for impact testing in which code considers RATED MDMT.
Que.2
Vendor has advice to reduce MDMT to 0 Deg. C
So Hydro test liquid temp. Will be = 0+17 = 17 Deg.C and we can use water at temp. 20 deg C.
But in this can we stamp original MDMT = 16 Deg C on the name plate or we have to stamp reduced MDMT on name plate.
Que.3
If I have ordered equipment to such country where in ambient temperature is colder than my RATED MDMT.
Does equipment fabrication will be effected like will material become brittle or fail. I know the stresses will not be generated as equipment is not in operating condition (Except shop hydro test condition)
How the ambient condition where equipment is fabricated is considered while desiciding Design temperature.
Or it like that equipment will fail only at MDMT when it is pressurises (Stresses are there).
This may be the reason we stamp MDMT on name plate as MDMT @ MAWP
Please share or views on that.
_________________________
Mitul Patel,
Static Equipment Design Engineer,
L&T Chiyoda Limited
Pathfinder Tags: ASME Hydrotest pressure vessel UG-99
Re: Hydrotest Temperature As Per UG-99(h)
05/20/2014 6:24 AM
Dear friends :
The first question:
The relevant provisions in UG-99 recommended that the metal temperature during hydrostatic test be maintained at least 30°F (17°C) above the minimum
design metal temperature. It means that the lowest wall temperature of your equiment during testing is 16+17=33℃ and the temperature of the water for testing should be maintained above 33℃.
If the actual MDMT is -10℃,you can use water at 20℃. But you should be monitored the Metal temperature during tesing and ensure the temperature higher than 7℃.
The second question
The MDMT established by current Division
rules may be different from that originally assigned but
must be suitable for the nameplate MDMT marking coincident
with the established MAWP.
The MDMT on the nameplate must be coincident with the estiablished MAWP, so if the reduced MDMT is coincident with MAWP, you can stamp the new MDMT on nameplate.
The last question
The equipment will have the risk of brittle fracture if it operating at the temperature lower than rated MDMT
If the ambient temperature is the lowest temperature among the all possible cases for equipment, the design temperature should not highner than the ambient temperature.
The lowest service temperature is related with applied loads, lower stress level can be sustained lower temperature .
