Previous in Forum: What could it be???   Next in Forum: Ten surprising health benefits of beer
14 comments
Good Answers: 181
Smart Thinking
01/14/2012 12:39 AM
Although you don't have to be an engineer to appreciate this story.
A toothpaste factory had a problem: they sometimes shipped empty boxes, without the tube inside. This was due to the way the production line was set up, and people with experience in designing production lines will tell you how difficult it is to have everything happen with timings so precise that every single unit coming out of it is perfect 100% of the time. Small variations in the environment (which can't be controlled in a cost-effective fashion) mean you must have quality assurance checks smartly distributed across the line so that customers all the way down to the supermarket don't get browned off and buy another product instead.
Understanding how important that was, the CEO of the toothpaste factory got the top people in the company together and they decided to start a new project, in which they would hire an external engineering company to solve their empty boxes problem, as their engineering department was already too stretched to take on any extra effort.
The project followed the usual process: budget and project sponsor allocated, RFP, third-parties selected, and six months (and $8 million) later they had a fantastic solution - on time, on budget, high quality and everyone in the project had a great time. They solved the problem by using precision scales that would sound a bell and flash lights whenever a toothpaste box would weigh less than it should. The line would stop, and someone had to walk over and yank the defective box out of it, pressing another button when done to re-start the line.
A while later, the CEO decides to have a look at the ROI of the project: amazing results! No empty boxes ever shipped out of the factory after the scales were put in place. Very few customer complaints, and they were gaining market share. "That's some money well spent!" - he says, before looking closely at the other statistics in the report.
It turns out, the number of defects picked up by the scales was 0 after three weeks of production use. It should've been picking up at least a dozen a day, so maybe there was something wrong with the report. He filed a bug against it, and after some investigation, the engineers come back saying the report was actually correct. The scales really weren't picking up any defects, because all boxes that got to that point in the conveyor belt were good.
Puzzled, the CEO travels down to the factory, and walks up to the part of the line where the precision scales were installed.
A few feet before the scale, there was a $20 desk fan, blowing the empty boxes out of the belt and into a bin.
"Oh, that," says one of the workers - "one of the guys put it there.......
cause he was tired of walking over..... "every time the bell rang".
Re: Smart thinking
01/14/2012 1:50 AM
A bit long, but worth the read. Thanks for the giggle, Tony.
Re: Smart thinking
01/14/2012 4:07 AM
Dunno if it's actually true, but it's gotta be pretty close.
Nice story.
Re: Smart thinking
01/15/2012 5:21 AM
Hi Del
I used to work for die-cast toy manufacturer in Hackney and we had a similar problem which was solved by the same method only a blast of compressed air instead of a fan.
Bazzer
India - Member - New Member
Good Answers: 164
Re: Smart thinking
01/14/2012 7:54 AM
A good story. Worth repeating any time. It is from pre-internet days, since i heard it as a young man, from an R&D veteran who quoted it as as an example of lateral thinking. Later called 'out-of-the-box' thinking....however, i believe a more apt title is 'not-in-the-box' thinking
Good Answers: 183
Re: Smart Thinking
01/14/2012 1:23 PM
I do not know if this story is true but I know of similar application where an air jet was used to eliminate under weight products. The jet was so set that its impact could not move the normal weight even in case of a malfunction.
They did not make in fact an analysis they only made a concept!
Re: Smart Thinking
01/14/2012 10:39 PM
a compressed air jet could be positioned under or next to a conveyor for removing empty boxes provided you dont have pauses in the conveyor movement as the jet can abrade a hole through the cardboard box / contents if one stops directly in front of it.
Good Answers: 183
Re: Smart Thinking
01/15/2012 3:57 AM
There were SMALL boxes, light weight, so that what you fear did not happen. The jet was so set that ONLY if tha box was empty its force was over the friction forces between box and band.
Re: Smart Thinking
01/15/2012 12:00 AM
Ha ha..... It's a joke guys! No need to analyse!
~Good Judgement comes from experience... and a lot of that comes from Bad Judgement! ~The Early bird may get the worm.. But the second mouse gets the cheese!
Good Answers: 25
Re: Smart Thinking
01/15/2012 5:17 AM
A lesson which has followed me all my life. Just because you have a brilliant
idea, it's not necessarily the best one. The moral: Always think again!
As a young man I had to provide water to calves in a building with no piped supply.
After some considerable thought and design, I bolted a normal galvanised drinking
bowl to the wall of the building, and after further considerable difficulty connected
a copper pipe, through the brick wall, from the bowl to a large water container raised
high up on concrete blocks on the other side of the wall. In all, about 5 hours work.
Proud of my efforts, I showed it off to a visiting farmer, and asked him how he
would have done it, thinking (big-headily) my system was simply brilliant.
He replied, " I would have given them a bucket with water in it?"
eeeeekkkk! But, a lesson that has stayed with me all my life. Even if one has
designed "sliced bread" - some one can, likely, do it a better way, think first!
jt.
Regret more what one has not done, than what one has done.
Good Answers: 25
Re: Smart Thinking
01/15/2012 5:41 AM
$8 Million wasted?.
Good Answers: 19
Re: Smart Thinking
01/15/2012 5:51 AM
True or not, it's a great story.
It recalls the charming but apocryphal tale of our Space Agency having spent large sums of money in the 1960's to develop a pen that would function properly in a zero-gravity environment.
The account continued with a remark that the USSR responded to the problem of malfunctioning ballpoints in outer space by issuing pencils to their cosmonauts.
Pencils were used by both US astronauts and Soviet cosmonauts early on, but the practice was discontinued because of hazards associated with broken leads floating around in zero gravity, and of keeping combustible materials (wood and graphite) in a pure-oxygen atmosphere. The "Space Pen" which US astronauts used later was developed with private money by Fisher, and Space Pens were sold to our government for less than $3 each.
I suspect that the toothpaste-box caper will join other good stories in the world of e-mails, and two or three centuries hence some literary descendant of the Grimm Brothers may collect it and publish it for the enjoyment of his or her generation and beyond.
Re: Smart Thinking
01/15/2012 9:31 AM
I'm sure the most complicated designs can be made simple. I raised a young man who broke every rule in the book and was basicly simple in his thinking..Out of creekbank thinking he could tackle the most complicated problem and change the way you looked under stress of not being able to complete a task..He would say, "Jim, let me show you how it should be done and do it....at 35 he is now proud he can read road signs
Jim
Re: Smart Thinking
01/16/2012 3:41 AM
Nice one!
Re: Smart Thinking
01/19/2012 10:47 AM
Employees (sometimes you very own) are a company's most valuable asset.
Register to Reply 14 comments
Bazzer Englander (1); bubbapebi (1); jt (1); jtd405 (1); Kris (1); kvsridhar (1); nick name (2); Nothing is Impossible (1); Part time thinker (1); PWSlack (1); suresh sharma (1); szwasta (1); user-deleted-1105 (1)
