Previous in Forum: Aluminum vs Stainless Steel Cable Winders   Next in Forum: Boiling and Freezing Points
How Can Produce Or Buy Aluminium Orthophosphate Dihydrate ?
01/14/2012 5:04 AM
I need " Aluminium orthophosphate Dihydrate " but my major is Genetics. I do not know how to buy or make this chemical . If you know some company which sells this please tell me. On the other hand if I could produce this chemical, please tell me the step-by-step.
Re: How Can Produce Or Buy Aluminium Orthophosphate Dihydrate ?
01/14/2012 8:35 AM
Go here: Search GlobalSpec type in name of chemical.
01/14/2012 8:47 AM
01/14/2012 9:45 AM
It is also used as a white pigment in paints. If you contact a chemical supply house, they may have a pharmaceutical grade.
Good Answers: 19
01/15/2012 12:22 AM
You haven't told us what grade you need. It has a variety of uses as a white pigment in paint, dental cement, ceramics, concrete, etc. It is also a hazardous material. Avoid skin contact and don't inhale the dust. If you need USP, Analytical Grade, or Technical Grade, contact a chemical supply house. If you need large quantities of lower grade material for an industrial process or a construction project, contact a dealer in building supplies, paints, concrete products, or whatever. Google is your friend. Use it.
Good Answers: 37
01/15/2012 12:43 AM
You may find it useful to search using both the European spelling ("aluminium") and the American one ("aluminum"), and to search on "aluminum orthophosphate" (and aluminium ditto), since the dihydrate implies that two molecules of water are attached to each molecule of the primary chemical - you may even be able to add this yourself - but websites of suppliers will likely provide several variants.
" Ignorance and arrogance have more in common than their last four letters. "
Good Answers: 102
01/15/2012 1:53 AM
....how to buy...
Find a supplier
Get a quote
Order and pay
Pickup or arrange freight.
Which part are you struggling with?
Register to Reply 6 comments
bubbapebi (1); lyn (1); Ron (1); SolarEagle (1); Tornado (1); Wal (1)
