Previous in Forum: DC Power Supply   Next in Forum: Unit Ratio Transformer
Reactive Power
01/14/2012 11:58 PM
how do I to generate the reactive power in a alternator?
Re: Reactive power
01/15/2012 12:44 AM
"Reactive power is a concept used by engineers to describe the background energy movement
in an Alternating Current (AC) system arising from the production of electric and magnetic
fields. These fields store energy which changes through each AC cycle. Devices which store
energy by virtue of a magnetic field produced by a flow of current are said to absorb reactive
power; those which store energy by virtue of electric fields are said to generate reactive
power."
"Most equipment connected to the electricity system will generate or absorb reactive power,
but not all can be used economically to control voltage. Principally synchronous generators
and specialised compensation equipment are used to set the voltage at particular points in the
system, which elsewhere is determined by the reactive power flows.
Synchronous Generators - Synchronous machines can be made to generate or absorb
reactive power depending upon the excitation (a form of generator control) applied. The
output of synchronous machines is continuously variable over the operating range and
automatic voltage regulators can be used to control the output so as to maintain a constant
system voltage."
http://www.nationalgrid.com/NR/rdonlyres/43892106-1CC7-4BEF-A434-7359F155092B/3543/Reactive_Introduction_oct01.pdf
Re: Reactive power
01/15/2012 6:42 AM
Alternators are also called synchronous condenser due to the fact that it can generate or absorb reactive power by controlling the excitation voltage of the alternators. Over-Excited alternators can generate reactive powers or leading power factor.
SAM
