Previous in Forum: Electrical Motor   Next in Forum: Reactive Power
11 comments
DC Power Supply
01/14/2012 12:26 PM
Hi,i really need help on how to design a dual channel DC power supply that fulfills the following specifications :
1) Operation - User selection between independent adjustment for positive and negative output voltage, and series tracking mode (slave channel tracks the master channel)
2) Output voltage amplitude : 0-20V± 5%
3) Current limit : 0 - 1.5A± 10%
4) Powered Directly from main supply
5) Indications of power on, constant voltage and constant current mode
I really hope you guys will be able to help me and provide me with a schematic to achieve the above specifications..thanks in advance =)
Re: DC power supply
01/14/2012 12:30 PM
Design? Why not just purchase one of many readily available power supplies?
Re: DC power supply
01/14/2012 12:34 PM
Because it is part of my semester assignment..and i have found the schematic for such a circuit in this link http://www.aaroncake.net/circuits/supply3.asp but i would like to know how can i make the circuit to produce an out put power from 0 - 20v instead of just 0 -15V..do you have any suggestions?
Re: DC power supply
01/14/2012 12:58 PM
Well if you had actually read the preamble to posting the initial question, you should have seen that we do not do homework. This will be robbing you of your education. I will give you one hint about where you should start. What do you expect the voltage to be after the diode bridge?
By the way, there's a significant error in the schematic you've referenced. Without a properly placed and sized fuse or circuit breaker, this design can eventually ignite and cause an electrical fire.
Re: DC power supply
01/14/2012 1:12 PM
you mean the value of the voltage??and what significant error would that be?
Good Answers: 102
Re: DC power supply
01/15/2012 4:05 AM
The answer is in T1.
Seriously now... you couldn't see this?
Anyhow, you should be learning about switch mode supplies not series regulated... that is so last century.
Re: DC power supply
01/15/2012 8:44 AM
There are advantages and disadvantages for each type (linear and switching) of power supply. Linear supplies are easier for a novice to understand. Linear supplies also produce very little interference signals. A switch mode supply can be made to produce very little interference signal but that requires a real skill of the field.
Good Answers: 11
Re: DC power supply
01/14/2012 12:41 PM
Step-down Transformer->Full bridge rectifier->Filter-> Fuse(1.5A)->Potentiometer-> Analog display Voltmeter & Ammeter--> Polarity switch
Consult the book for calculation.
Re: DC power supply
01/14/2012 12:45 PM
Thanks for the help..appreciate it =)
Re: DC power supply
01/14/2012 1:52 PM
Quote " What do you expect the voltage to be after the diode bridge?"
Answer the question Julian. If you want 20 volts out what do you need to do?
Re: DC power supply
01/14/2012 9:25 PM
I guess we scared Julian away by not doing his homework for him. I wonder what grade he's going to get?
Good Answers: 70
Re: DC Power Supply
01/15/2012 12:18 AM
If I had known better, I would have thought this was the same guy here. And, here I thought Finals were over for the season
dj95401 (1); Julian (3); Noudge79 (1); redfred (4); Wal (1); wareagle (1)
