Previous in Forum: Transmitter on Tank   Next in Forum: Loop Diagrams
2oo4 Logic (2 out of 4)
01/16/2012 2:15 AM
Dear All,
How to implement 2 out 4 logic using And /Or gates .
Thanks
Re: 2oo4 Logic ( 2out of 4)
01/16/2012 7:11 AM
2oo4 means minimum two logics to be high for getting output at the another end....this will help you. Minimum two inputs out of four is to be high, this could be 3 or all of inputs could be high for 2oo4 logic.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
01/16/2012 11:11 AM
So as to not confuse the OP, the outputs of all the AND gates shown need to feed into one big OR gate (or a network of cascaded OR gates functioning as a 6-input OR gate). Here is an example using all 2-input logic gates:
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Good Answers: 46
01/16/2012 11:31 AM
Oops -- I was a little too hasty with my diagram. Here's a simpler version with one less OR gate required:
Good Answers: 183
01/19/2012 10:21 AM
The table shows the required combinations: arrangements of 4 taken 2 =4*3/(1*2)=6The scheme copies the table. OR-gates with 3 entries are available as 4 units/chip.It can be build with 2 chips. I was not careful enough previous time I hope to be this one.
Good Answers: 183
01/16/2012 8:02 AM
The condition can be also written as below (if I am not wrong):
"If a or b and c or d are high then output is high".
You need 2 "or - gates" and 1 "and - gate" = 3 gates.
The less components you use the less problem you can have.
01/16/2012 8:26 AM
What about [a and b] or [c and d]?
Good Answers: 46
01/16/2012 11:13 AM
Unfortunately, this logic will not cover the cases [a and c] or [b and c] or [a and d] or [b and d]. A true 2oo4 system must work on *any* two inputs out of four.
Register to Reply 7 comments
harjeetsinghengg (1); nick name (2); PWSlack (1); tonykuphaldt (3)
