I have a double capacitor bank, in a subestation 13.2 KV-440 volts, with three transformers, 750, 500 and 112.5 KVA.
The capacitors are for f.p. compensation. Each one of the capacitors bank is for 50 KVAR, 480 volts, plate data.
There was a failure that provoked the outage of the whole subestation, causing the surge arrester of the main entrance of the subestation to fail. None of the transformers suffered any harm. It seems the origin of the problem was a loose conection in the capacitor bank's switch.
Having no lab equipment for testing capacitance, how can I test whether or not the capacitors are damaged ? The capacitor banks are delta connected. Of course I do have means for applying variable a.c. voltage, multimeter, and apparatus like that.
Thank you for any comment
