Previous in Forum: Power System   Next in Forum: Cost Comparison Power Transfer at Different Voltage Level
Harmonics
01/17/2012 5:06 AM
Question: In electrical engineering how is harmonics become a measure of Power supply quality?
Whats the ideal pattern for harmonics, how can distorion be corrected? How does it affect load equipment?
Whats the electrical component that is succeptible to be affected by harmonic distortion?
Anonymous Poster #2
Re: HARMONICS
01/17/2012 6:04 AM
Good Answers: 11
Re: Harmonics
01/17/2012 7:36 AM
Good Answers: 170
Re: Harmonics
01/17/2012 11:12 AM
i) Harmonics is one of the measures of power quality. Apart from the continuity, voltage & frequency limits, the voltage wave form must also be as close to sinusoidal as possible. Harmonics distorts this wave shape of the power supply and thus it affects the RMS value of the voltage and/or current. Thus, it becomes a measure of power quality.
ii) There is no "ideal" pattern for harmonics, for harmonics itself is away from the ideal. It contains all haphazard patterns. Distortion can be corrected by the provision suitably rated harmonic filters or by avoiding the use of harmonic generating equipment. It affects load equipment by skin effect, by negative sequence currents, by hot neutrals, etc.
iii) Almost all electric components are affected by harmonics, rotating electrical equipments being the most vulnerable.
Re: Harmonics
01/18/2012 10:05 AM
Is employing AVR helpful to eleminate harmonics? What does AVR do to power supply?
Re: Harmonics
01/18/2012 6:57 PM
Nop.. AVR is used to mitigate over/under voltage problem. To suppress harmonics, you need filter.
"I know less than all, but more than many who know less"
adhyartha (1); Anonymous Poster (2); electricalexpert65 (1); Noudge79 (1)
