Previous in Forum: Pigging Facility Without Pg Traps   Next in Forum: Velocity Effect on Pumping
8 comments
Pipe Support Type for Compressor Outlet
01/18/2012 4:41 AM
Can you just tell me which will be the type of support at outlet and inlet of a reciprocating H2 Gas compressor? Is there any vibration effect with normal support? The line has hot insulation and pressure is 34 KG at outlet.
Re: Pipe support type for compressor outlet
01/18/2012 4:54 AM
Surely there is a mechanical design drawing for this area (rhetorical question)?
Good Answers: 16
Re: Pipe Support Type for Compressor Outlet
01/18/2012 9:15 AM
Is there a vibration effect? YES
Your system piping should be supported as per normal standards depending upon its diameter and physical location (horizontal, vertical, overhead, etc) you should have a flexible joint or flexible connection between the compressor outlet and the rigid piping.
Many applications as this will employ a S/S expansion joint to handle the vibration.
Good Answers: 61
01/18/2012 11:39 AM
The previous poster (Tim in Mexico) wrote:
"you should have a flexible joint or flexible connection between the compressor outlet and the rigid piping."
This is ABSOLUTELY WRONG for any reciprocating compressor piping. Do not use any flexible joints or flexible connectors, make the piping configuration along with the proper type of pipe supports located in the proper place.
Do it once and do it right
Good Answers: 16
01/18/2012 12:02 PM
Ok then, so you feel it is correct to have the rigid piping connected DIRECTLY to the compressor, nothing to absorb the units vibration?
So you are saying the piping and its connection to the compressor itself is meant to absorb all vibration and stabilize the compressor???
Its funny to see how far from the restraints of reality you are sir.
You can call me ABSOLUTLY WORNG, I've been called worse than that, just don't call me late for dinner! I have also installed more than my share of compressor systems.
Original poster should find a reputable engineer to visit his application in depth PennPiper is just a little to sure of himself (my humble opinion).
This was not written to start a little pissing match either, so lets not go down that road ok?
01/18/2012 9:08 PM
Normally it has been seen that flexible joints are avoided in Reciprocating compressor's suction-discharge pipings. Yes rigid piping with suitable loops are connected to suction and discherge surge drums which are normally connected directly to cylinder block nozzles. In fact compressor dynamics and stability is designed taking consideration of rigid piping without flexible joints.
Good Answers: 67
01/19/2012 6:09 AM
GA Mukesh, your answer may satisfy both Mr Tim & Penn, where coments went on little off road. In fact, suction and discherge surge drums and after coolers absorb a lot of vibration.
Good Answers: 16
01/19/2012 6:37 AM
GA
Good Answers: 67
01/21/2012 3:34 AM
Your GA for Mukesh was some how not counted, only my GA is counted. Please try once again.
Mukesh0861 (1); PennPiper (1); pritam (2); PWSlack (1); Tim in Mexico (3)
