Previous in Forum: Parking On A Ramp   Next in Forum: Dim Turn Signal
12 comments
Compact Electric Air Compressor
01/18/2012 11:17 AM
Is there a compact air compressor in the market, which is powerful enough for the intake air of the IC engine? Thank you.
Re: Compact Electric Air Compressor
01/18/2012 11:19 AM
Why not use the exhaust gases to turn it instead [turbocharger]?
Why not use the engine's driveshaft to turn it instead [supercharger]?
01/18/2012 11:57 AM
This is for an experimental two-stroke engine with an intake valve (no oil/fuel mixture intended). A supercharger is to be supplemented with a compressor or vice versa.
I am not sure there is any compact yet powerful compressor practical for this use.
I am hoping my design could be used to convert current 4-stroke engine into 2-stroke and save weight, fuel and ... before the electric cars are more prevalent.
01/18/2012 12:02 PM
Why an electric compressor? Other ways of turning it have already been described, and are immediately more applicable. What happens to the engine when the supply fuse feeding this conceptual electric compressor goes open-circuit due to a fault?
01/18/2012 3:25 PM
To PDSlack: I tried to send you my engine design in order to explain my problem. But I am having difficult attaching a graphic file. Will you send me your email address to mine; . The graphic will be sent right away.
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
01/18/2012 11:28 AM
What size IC engine....and no....maybe a blower(see leaf blower)
01/18/2012 12:15 PM
The size of each cylinder is assumed at 600-800cc. Pending number of cylinder of the engine, the compress should have the capacity to feed sequentially or .. similar to the fuel-injection system. Is the leaf blower type compressor efficient enough?
Good Answers: 299
01/18/2012 11:28 AM
Sure, if the IC engine is for a leaf blower.
01/18/2012 12:12 PM
Yes, but a belt driven blower is more practical.
This is a Sonic Air system. I've used them many times in the past and think they are great. Not an endorsement, just the facts.
Sonic Air Systems
01/18/2012 12:23 PM
Guess it will be hard fit into a compact car compartment.
Btw are they hot dog?
01/18/2012 1:00 PM
The picture is of a food processing line. Didn't even realize that when I copied it.
01/18/2012 2:16 PM
Is that machine a weiner blower?hehe
Good Answers: 58
01/18/2012 9:59 PM
I think I saw a Buick once that claimed to have an electric supercharger. The big question for you is: can this blower produce more horsepower than it draws? No sense hanging another blower on a supercharged motor if the return is less than the drag. You have to power this blower somehow!
The main thing is net gain of horsepower. If you want some more power, alter the fuel.
mike k
Register to Reply 12 comments
David Yang (4); Doorman (1); lyn (2); mike k (1); PWSlack (2); SolarEagle (2)
