Previous in Forum: Electrical vs Mechanical Horsepower   Next in Forum: Current Transformer
Spemos Card C1 (Power Supplying Card) Problem
01/19/2012 3:02 PM
Dear fellows, In onw of our DG ( wartsila ) spemos card C1 is getting burn everytime after running few hours smoothly.. we have changed twice the card but same is happening again and again..I have checked the power supply to card it is fine.also checked the other wiring like sensors etc.
Can any one suggest me what can be the problem???
Re: Spemos card C1 ( power supplying card) problem
01/19/2012 3:26 PM
Since I haven't got a clue what you're talking about: I suspect that this is a very low volume card for a specialist application, and, I bet the manufacturer has accidentally made a whole batch with an electrolytic capacitor fitted the wrong way round.
Does C1 look something like this:-
If so use a DVM to check that the power supply negative (0V) input to the board is connected to the -ve side of the capacitor (this side in the picture) and the positive input (12V?) is connected to the +ve side of the capacitor.
The capacitor in the picture is rated at 25V. I suppose it is also possible that the ones fitted are not rated at or above the power supply: say a 4.7 or 6.3 volt cap. on a 12V rail for example.
01/19/2012 3:36 PM
Dear .C 1 is an electronic card in Spemos(wartsila engines speed monitoring system). There are 3 other cards too in this system . the function of this card C1 is to provide smooth 12 VDC supply to all other cards. It is getting 120 V DC input and there is DC/DC converter for smooth output voltage (12 V DC)that is being fed to other cards.It does not look like you showed capacitor..I will upload the picture of the card at some other time..
01/20/2012 5:39 AM
Yes a photo of a burnt and unburnt card would help:-
Where is the 120V DC coming from?
Register to Reply 3 comments
