Previous in Forum: Spemos Card C1 (Power Supplying Card) Problem   Next in Forum: Control Panel
Current Transformer
01/19/2012 10:01 PM
Hi,
Very Good day to all.
Would someone explain for Current Transformer. How do I easy understand CT 3x3 1500A/5A.
1.CT ratio
2.Prim current
3.Sec Current
4.Burden
5.Plugged on V phase?
Thanks advance.
Re: Current Transformer
01/19/2012 10:35 PM
01/20/2012 4:23 AM
Hi,
1.CT ratio - 1500/5A. Means when 1500A flows in your primary, you can measure 5A in the secondary.
2.Prim current- Current which flows in the primary winding of CT. In your case, 1500A
3.Sec Current- Current which flows in the secondary winding of CT. In your case, 5A
4.Burden- How much load the CT can feed without errors in the secondary circuit. (Load means relays, meters)
5.Plugged on V phase? - I am not getting you. Be more specific!
Thanks,
Vijay.P
You don't understand anything until you learn it more than one way.
Register to Reply 2 comments
