Previous in Forum: Voltage in Saudi Arabia   Next in Forum: Glue Sensing Device/Sensor
Kohler Generator AVR Adjustment Procedure
01/23/2012 1:10 PM
Dear All,
Has anyone ever came across adjustment of parameters (voltage, gain, U/f) of AVR (type:A-360420, PCB ASSY, FR2 RMS Reg., 12V, 12-Lead) for Kohler Generator 20-200REOZJB ?. If yes, is there a dedicated procedure for above mentioned activity you could share with ?.
Thanks in advance,
Paata
Re: Kohler Generator AVR Adjustment Procedure
01/23/2012 2:50 PM
You might try contacting a dealer...
http://www.generatorpanels.com/downloads.asp
01/24/2012 10:18 AM
Thanks for advise
05/16/2012 12:44 AM
hello paata , to adjust the AVR voltage or hz you need to connect your voltmeter to line and neutral then do the adjusment tunr clockwize or counterclwz while your are doing that you will see your multimeter volt reading either up or down the voltage same the adjustment of hertz , but if you do that the generator should start warning always use rubber safety glove, you can find the AVR inside the panel box of genset alternator !!!!
i want ot helf piple need assistance and to share my knowleged in technical
Good Answers: 58
01/23/2012 2:53 PM
Have you contacted Kohler and requested their adjustment procedure?
Kohler should also have "start-up" (usually) sub-contractors. If Kohler cannot help you (highly unlikely) ask Kohler for contact information for one of their start-up subs.
01/24/2012 10:20 AM
Thanks. I will try to contact Kohler.
KJK/USA (1); Paata (2); SolarEagle (1); toink (1)
